Intake modification Again...
jdeoliveira74
wilmington nc
Ok so here I go again... Moding the 6.2 banks air box to accomodate more air. The original intake opening was only 2" od. So now I will do two snorkels.. The Plan is to re run both very close up the windshield and come right over the top of the truck, and connect in the center. Its going to double as a light bar also
Shrapnel
Just a Hoosier stuck out west!
Delta, UT
I'd always thought it would be cool to run two air inlets to the headlight buckets and then mount DOT approved lights in the bumper. Kind of a forced-air setup.
Probably not good for water crossings or even rain, however.
Nice setup!
firefirefire90
Honolulu, HI
maybe this is just me being OCD, but are you going to make that any bit more symmetrical? As in on either side they look the same. Example: E60 M5 engine bay: 2 separate intakes, but they both look like the other just flopped.
jdeoliveira74
wilmington nc
yes the side with the open filter is temp. Till I can get the new snorkels made and roof light bar attached
jdeoliveira74
wilmington nc
Ok test run today truck is definately has more power. Towing today I felt a big difference. Fuel mileage seems to be better but its hard to say till I get it out on the road and go for a long haul. Probably thursday for that then I can get a better feel for it.
dmilkman589
troy, ny
i was thinking about just taking the original cap and cutting the same size hole but on the opposite side. what kind of benifits do you think i could get from that? i mean it would be technically doubling the size of the whole
jdeoliveira74
wilmington nc
the only proplem with the stock air cleaner housing is the more you open it up the louder the engine gets. I stacked two air cleaners on top of each other at first and it was so loud in the truck you couldnt even hear yourself think. If you cut the second hole I suggest you run a duct from the hole to the front of the radiator . But I do think you will feel it a bit in the torque
jdeoliveira74
wilmington nc
Havent gotten that far for mpg. but as far as torque I felt a big difference. I think I am also going to raise the air box about 3" higher which should help some more. I will know better on my next highway trip end of week
bushhawg73
Columbia, Missouri
I sure wish I could find the banks part so I could do somthing similar, The junk yards around here are few and far between. Anyone have a suggestions on sourcing the needed part?
jdeoliveira74
wilmington nc
ok So the wifey drove the truck yesterday cause her's is in the shop. She did around 215 miles around town and highway and used a little less then half a tank. so looks like around 430 to a tank. I will have a better idea tomorrow. I have a 4hr trip towing tomorrow
