Glider
- 155
- 43
- South Pittsburg, TN
I'm wanting to install interior lights and USB chargers for cell phones. ill list below the items I have or am ordering.
So far I have 8 led rock lights like this: https://www.harborfreight.com/12-volt-utilityrock-white-led-light-2-pk-57205.html (will draw 35watts total)
I am considering these usb mounts: this for driver https://12vtechnology.com/products/...v-w-60-inch-wires?_pos=9&_sid=ec5853530&_ss=r and the same dual setup for passenger with voltmeter swapped for 2 additional usb ports.
This rocker panel: https://www.ebay.com/itm/202024543352
All of these components are safe with 24V input. Actually, the USB despite saying 12v is good with up to 30v input according to the manufacturer. I plan to mount on underside of radio tray and would like to be able to unplug for service.
I am looking for help on how to wire as if AMG would have done it and use matching packard connectors and proper wire. I would like all power switched so all dead when start switch is off. I plan on mounting 2 lights in bar just above and behind front seats, all footwells and 2 in bed. I would like a rocker switch mounted in this area and one on passenger side somewhere so either driver or passenger can turn on lights. While I am at it I would like to rewire headlight/service light switch to come on and off from start switch so I can leave on all the time.
All suggestions appreciated CAMO, are you out there?
