airmech3839
- 5
- 18
- Augusta, GA
Have looked through some searches and have seen some stuff on hard starting but I am having some difficulty that I think is related to the cutoff rod on the IP. I do have a small returnline leak so that is half the problem.....I was driving to work in the beast and stopped for fuel......shutdown....then went to crank back up......it turned over but no go.....checked cutoff linkage to make sure the rod did not get stuck out.....it appeared to be in but I went ahead and pushed it in by hand at IP and it didnt budge so its in.....I scratch my head a min....trying to think this through.......opened drain cocks on bottom of filters and the one on top to insure no vapor lock while accy switch was on....got fuel so I tapped side of IP at rod lightly.....got in and it fired right up........huh....got to work.......would not shutdown cause I could not pull cutoff handle......had to pop hood and do it the old fashioned way and it was so stuck in I had to use a pair of plyers to force it to come out enough to pull cable to shut it down....I am at work now and I have tools here....just hoping I can get her cranked tonight....I would rather work on it in the daylight in the morning at my house!!! Any thoughts...just sounding off....I will take what rolls....I think it is the rod and or that part of the IP that is the problem....am I right???
