IP lube line
cranetruck
94
Meadows of Dan, Virginia
From the "Florida round up" thread:
fordlotus said:
Here's a tip, I was taking one of the dumps from gainsville to cocoa last month and there is a little 1/4 inch cloth braided oil line about 6 inches long that runs behind the fuel injector pump on the 465 1a. Check it regularly! It burst in Ocala and dropped approx 6 gallons of oil on the grond in a matter of seconds. Before I could get off the road and shut it down the rods bearings were knocking. It went back to gainville under tow. Check this hose. if there is a slight fuel leak on it it may break down faster.
I think this is important enough to show in detail. The oil line is shown in the images below. It connects to the fitting labeled "B" in the second picture.
jwaller
19
Columbia, SC
I spoke with the guys at memphis equipment about an oil leak I was having on my IP and he told me they had only sold about 3 of these lines that he could ever remember.
3,151
That's 'cause you can make it probably alot cheaper than Memphis sells it for. It's only a 1/8 NPT on 1 end and #4 swivel on the other end.
3,151
The return for a bypass filter should be returned directly to the crankcase. Flow thru the filter isn't enough to be put back directly to a component that needs pressure and flow. Damage to the component will occur.
