is it posible to?
Mitch
TX
Is it possible to change the engine out of M900 series truck and put in a Cat C15? Also what size tires should I purchase and from whare? I am looking at buying an M925.
wreckerman893
Possum Connoisseur
15,644
2,127
If you have the money and determination you can do anything.
That being said if the engine will fit the bellhousing without any major modification you would be ahead of the game.
If the puddy tat has a lot more power than the Cummins you may have tranny issues.
My only problem with Cat engines is that they charge way too much for that yellow paint job.
Cats are not cheap to keep. Especially the new electronically castrated ones.
Just my 2cents
3,130
Who's gonna make the harnesses? You'll need to add about a 1/2 mile of wire, a bunch of stuff so the trans will work with the engine...will the trans handle the torque, what is it, 1850?
Mitch
TX
engine stats
Displacement 15.2L
HP 625@2100 rpm
2,050 lb-ft@ 1,200 rpm
18.1 compression ratio
engine weight 2,890lbs
oil capacity 41 quarts
