tucker79
- 0
- 16
- S FL. United States
Ok Iv searched threads for weeks nothing quite like my problem
Dropped front drive shaft
I have flushed with diesel few times pretty clean compared to others Iv done with great success
Iv pulled and cleaned up air shift cylinder was some junk in there as I believe my air tanks got some junk in there but not leaking
Iv checked poppet valves and they were very clean n not leaking
So the problem is when I jack up a front wheel when in 1st the wheel will NOT spin either direction. In neutral the wheel spins the entire tranny Sprag locked in. This only happens when its aired up, with no air the wheel spins freely in both directions
I still feel that it may have something to do with the air shift system because it disengages with no air but when I had the air shift cylinder out I was still having the same problem when I manually shifted it forward to reverse.
Any Help or suggestions would be awesome and no I did not let it roll back in forward sorry to bring up the hated Sprag subject but I dont see this particular issue in past threads If there is any info you can direct me to a thousand thanks
