Is this a bad Power Steering Pump?
tgejesse
284
Maryland
When I got my new (to me) M1165,
I was able to get the non-runner…. Running… by adding batteries and a start box. Pleasant surprise.
The not so pleasant surprise was the steering. There were some pretty awful high pitch noises and felt like the PS was completely dead.
After bleeding the system multiple times, the power steering finally engaged but now has a pretty aweful sound when steering and breaking.
Here’s a video of the sound. Maybe someone who has had issues with their PS might recognize the noise.
Love to hear what you think!
Maxjeep1
1,912
Las Vegas Nevada
I read somewhere that you need to get the front wheels off of the ground and turn it stop to stop 30 or40 times. It was a ridiculous amount of times. My M1165 was empty on the resevore and I filled it up and I had the same issue and it was starting to get better and then I realized that I had a leak. I haven’t messed with it since. I’m saving up for a generator and I will fix it all at the same time. I did just replace the steering gear on my H2 and it took forever to get the air out and my brake pedal was not right either. I think you just need to bleed the air out and it will be fine
tgejesse
284
Maryland
I turned the steering wheel close to 200 times both lifted and then on the ground.
If there is still air in the system it’s probably a leak like you said.
Was your leak a damaged line? Loose fitting?
Maxjeep1
1,912
Las Vegas Nevada
I believe it’s leaking from underneath the reservoir probably a rubber hose. When I pull that 400amp generator off I can see what’s really going on. When I did the injection pump I did notice that the bundle of hoses wrapped together with a silver tape was wet.
royg
131
33
slc, ut
You're on the right track here. Solve all your leaks first before you trust your efforts are bleeding the air out. If fluid can escape air can enter. I had similar noise on one of my trucks and in the end it was a leaking connection very well hidden on the back of the pump under the alternator bracket. It was alot of work to get to/clean up/replace the hose but it solved my problem without much cost.
