Is this an A3 filter??
tonidial
marion, il
I have recently acquired 2 pallets of surplus parts - mainly bearings and filters for CUCV and 2.5t trucks.
I'm presently sorting through the stuff to see what I have and found numerous filter kits NSN 4300-00-884-4801
The kit consists of a fluid filter/ some cotter pins and gaskets - but one gasket has an 8 bolt hole pattern similar to a wheel-hub gasket.
NSN search by using GL NIIN/NSN report from IHS, The Source for Critical Information and Insight (tm)
That says the end item use is a 2.5t - but it sure doesn't look like the filter kit I've put on my LDS engine
O yeah - I have 2 pics/ 2nd pic partially shows gasket that looks like a hub gasket.
Warthog
240
OKC, OK
Listed in the Deuce parts Tech Manual TM -9-2320-209-20p , TM 9-2320-361-24p and others. It is also listed in the 5-ton multifuel manuals.
tonidial
marion, il
Thanks guys - the multi hole gasket threw me off - I figure it has a purpose but not sure for what since my A2 filter canisters are all single bolt. Then it occured to me it might be the cracker jack prize in the kit :p
