Issue with motor swap
Braymond1
Fort myers beach Fl
Ok so let me just say. I’ve exhausted every outlet I could find before asking this question. I just put a new crate 6.5 in my M998. Previous it had a 6.2 . However when plugging everything back in. It seems I can’t find where 458 C and 458 D go. I’ve googled,looked up wire diagrams,and gone through just about any manual I could find. I know 458 A and 458 B go into the thermostat senor. But it’s killin me. Cuz I have zero clue where the other 2 go. I have 2 other M998s and cant even find the C and D on them. Any assistance would be greatly appreciated. Thanks
Retiredwarhorses
4,572
Brentwood, Calif
Without looking, isn’t that the Tcase lock lamp wire harness…plugs in, in conjunction with 458A and B.
it uses the 24v to light the lamp…
Action
1,564
East Tennessee
there are a 458a and 458b that connect to the temp sensor
in this image, #4 looks like a jumper with 2 458a; #5 is 458d; #3 is 458c
you can open a service TM and search it for "458c" and such
Mogman
10,451
Papalote, TX
If it is the T case lamp you will not have it on a M998 that had a 6.2L
Mogman
10,451
Papalote, TX
Well that would be simple enough to figure out, does the truck have a TC lamp?? does it have a slip yoke on the rear output shaft?
Seems if it did he would have someplace to plug in the harness
Braymond1
Fort myers beach Fl
No it does not have a TC lamp. The outer housing is there With a clear window. But nothing underneath. Just a little background on my M998. its a 1994 and yes I’m aware that normally 94s came with a 6.5L. For some reason mine did not. Now I do have a 1987 Humvee that was redone in Maine before I bought it. That does have a 6.5L in it. I tried to find 458C and 458D. But couldn’t find anything. However it does have some form of spliter off 458A and 458B. Of course the wires plugged into the splitter don’t have #tags on them. Again I do really appreciate everyone trying to help me figure this out. Cuz this particular Humvee is my favorite and the one I’ve done the most work to.
Braymond1
Fort myers beach Fl
According to the TM, his 2 open wires are up by the alternator.
I have looked everywhere and see nothing not plugged in. i didn’t put this on first post. mainly cuz I thought my question was one of common sense that I was just overlooking. But the 2 plugs that need a home. One is male and one female.
Retiredwarhorses
4,572
Brentwood, Calif
you just literally described a 242 tcase equipped truck
