Unless you hit something and bent the frame the above is the most likely cause. The rubber bushing that go in the front shackles is available at NAPA for about $20How about a picture of the rear shackles on the front spring? Is the eye of the spring resting on the frame? I would guess that is where you are getting the set back.
You can say that again! Put new ones on mine and even with the plow raised in still sits higher than before WITHOUT the plow. Rides better too.View attachment 755767A new set of leaf springs will cost a bit but well worth the effort. Trust me I have been putting them on several of the CUCV's I rebuilt. Amazing what difference 30 year newer springs make. View attachment 755768View attachment 755769
