- 7,426
- 2,538
- 113
- Interlachen Fl.
I saw that someone on the board got one of these and just wonder about the interchange. It looks like a late code G pump and that I believe acording to the TM's has the HH that was oil lubed. If that is correct then this lower unit could not use the newer head without the oil block off kit. The HH also could not be taken off and used on the newer lower unit as it would need the lube oil and no passage is on the outher lower unit IP. Thoughts?
