LDS engine stalls at low speed or take off.
gimpyrobb
dumpsterlandingfromorbit!
27,787
779
Cincy Ohio
You say you cracked the lines at the injectors. If it was a bad injector, one would make no difference in idle(when cracked). Was there one that made no difference?
docharley
Duncan/North Carolina
Turbo spools up and is working. I am going to pull and check the injectors and check valves in the am. I am going to try to track down which cylinder is not firing as well. Will also see about checking injector pump engine timing. Busy day. Let's see what happens. Still need to find TM's for Valve clearances, injector servicing, and pump timing for LDS engine.
cranetruck
94
Meadows of Dan, Virginia
Here is some timing info for you. Follow the instruction to confirm the engine setting.
Instead of a barring wrench, put the transfer case in neutral, shut off fuel delivery and turn short drive shaft between transfer and gear box.
docharley
Pulled 3 injectors. One injector has a nice shiney black tip on it. The other 2 are coked from the engine firing. I know I have atleast one bad injector. Any ideas on what I should pay for injectors?
docharley
Replaced one injecter, removed and checked all of the rest. Missing got worse after I replaced the filters. Still have cylinder miss. Low RPM miss is really bad. High RPM cylinder misses then fires for awhile then misses again off and on.
docharley
Does anyone know anyone that works on these things? I've had it with this &*$(*&# thing. Everytime I trouble shoot something it only seems to get that much worse. Tired of throwing good money after bad.:idea::shock:
AMGeneral
116
Connelly Springs, NC
Depending on exactly where you are located in NC,there's Jon Winslow in Halifax,Jim Henry in Albemarle,Charles Talbert in Norwood, All 3 are expierenced with multifuels.
docharley
I am about equal distance between Albemarle and Halifax. I'm over the temper tantrum :( Do you have the contact information for them? I am going to check the clearance on the valves. See if I can find a creative way to turn the crank.
Thanks.
docharley
I pulled the injector that I replaced and put the old one I tried to clean back in. The truck actually smoothed out and rine fine for about 2 minutes and went right back to missing again.
