Leaf Spring Bushing R&R
MatthewH
Boyne City Mi
Tore out the front springs from my '53 M37 so I could get them re-arched and rebuilt for 2"lift. Noticed upon removal the pins were worn, as well as the bushings them selves.
Ive got new pins, bushings and outer shackles order and headed my way, have some NOS inner shackles on my shelf waiting to go on.
Having read threw the TM, I understand how to complete this job, but does anybody who has been down this road have any tips, tricks, and/or recommendations how to make the job easier, especially the bushing removal? Have to say, first truck I've messed with that uses bronze bushings, usually there rubber, I burn em out with a torch and press new ones in.
GUNNY 155
elgin illinois
You should be able to clamp the eye of the spring in a bench vise and drive them out with a bushing driver or a old socket and extension. The old bushings will be harder to get out due to rust and dirt, the new bushings are not in there that tight you should be easy to install after you clean the eyes up. When I did mine I did have to take a hone to the bushings to open them up a little to fit the pins. They should be a nice slip fit. I had to match fit each pin to the bushing it will be installed in and keep it with that eye. To make them last when it is time to grease them, jack the vehicle up and support the vehicle under the frame so the weight is off the spring make sure plenty fresh grease comes out both sides of the bushing. This extra step insures you get grease on the load bearing side and not just the bottom side of the pin.
54M37
Darlington, MD
The front springs also have a bushing in the frame. It's a good idea to change those also if you have the springs off. The spring eye bushings come out rather easy compared to the ones in the frame.
MatthewH
Boyne City Mi
They went pretty easy. As mentioned, the frame bushings for the front were a pain to remove. Alot of time with a chisel and hammer to get them out.
Just have to finish up rebuilding the steering components and the front should be done
