JTugwell
- 3
- 0
- Pensacola, FL
I know this has been covered a thousand times, but bear with me. I replaced my front seals, and boots not to long ago. it appears that the passenger side is leaking again.
i have a drip coming from the lower kingpin plate. i knew this might happen because my retainer was really loose. i actually pulled it from the axle by hand. the other one i had to drive out with a pipe. i put some permatex around it when i put it back in hoping that would help. i guess not. can you get these retainers anywhere? i haven't been able to find them. Or does anybody have any tricks of the trade where i can make it seal up good? of course this is all an assumption on where the leak is coming from. i haven't torn it down yet, but its my best guess. i know the seals were installed correctly. i have read other posts while searching that this could point to the vent. can you get these as well? if im gonna do the seal again ill go ahead and change that vent too. Thanks!
