leaking flame starter
sparkylisle
Somerville, TN
My flame starter is leaking and I want to bypass it until I have a chance to fix it. There are two fuel lines connected to it and I was wondering if one is the supply and one is a return or are they both supply lines??? :lost:
cranetruck
75
Meadows of Dan, Virginia
The skinny one is supply. Most likely the return line is leaking fuel from the general return hoses. You can plug everything without a problem.
sparkylisle
Somerville, TN
Re: RE: leaking flame starter
THANKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
jimk
45
Syracuse, New York
RE: Re: RE: leaking flame starter
Mine was leaking too.I tried to refurb the self align compression ferrule(olive in the UK) and broke it. I tried a std 3/16 compression ferrule. It cocked on the tube and leaked worse. I put a tube sleeve inside and used a new ferrule. That solved the problem. I could not find [local] the correct ferrule. JimK
