Leaking fuel Line
acetomatoco
9
rubber fuel line is the way to go... just cut out the bad section and put in the rubber with worn drive stainless steel clamps and because it is just the fuel delivery and return lines under low pressure you will be fine... Taking the cab off will take more than 29 minutes. You will note that the lines are connected to the tank with rubber anyway...and they tend to get porous thru ozonification.
