- 849
- 1,739
- 93
- N. Central Idaho
Last year I serviced the 4 rear hubs. I used the Green RTV as opposed to the cork, per tactical repair. I tried to make certain everything was squeaky clean. NOS seals, not after market and repacked all bearings inner and outer. Torqued the inner nut to 50-lbs backed off 1/8 to 1/4 turn. Everything was fine and I made a number of short trips.
I recently changed the fluid in both aft differentials. Now I have leaks. I may have overserviced using the finger method of checking the level and I have been making longer trips. Two were showing on the wheel/tire. The third seemed ok but when I pulled the hub locker off it ran out and grease looks like vaseline..sort of. Mixture of the fluid and the grease I'm guessing.
Can over servicing cause this due to heat expansion creating pressure?
