Little help here ....
heywood
goshen/alabama
Does anyone have a good crossreference covering all the fluids in a deuce?
Military to civilian equivalent.
I have the lube Order TM but need civilian substitutes.
sandcobra164
287
Leesburg, GA
I use Shell Rotella T 15/40 for the motor, Prestone Ethylene Glycol (green) for antifreeze, Traveller (Tractor Supply) 40W Non Detergent oil for trans / transfer case, Napa 90W GL-5 oil for axles, DOT 5 Brake fluid (commonly found at a Harley shop) for Master Cylinder. That should about cover it.
