Location of Switched 24V source?
linhster
Delray Beach/FL
Trying to add 12v step down converter in the back seat compartment. Where is the closest switched source I can tap into? Thanks for your expertise knowledge in advance.
Dock Rocker
71
Jackson ms
I would use a signal wire tied to the starter switch hotbside and run that to a fuse and relay. Take the power from the relay and make that your switched power.
linhster
Delray Beach/FL
Thought of that but was sure how much current would be pulling from the solenoid switch so I decided to use the lead from the blower switch since I don't use the blower much in Florida.
