Log of my 1995 Hummer
TOBASH
3,945
Brooklyn, NY
1995 with lots of upgrades.
I get her back from Tor Sunday. Then I can start work on her.
Drivers’ heated window replaced. I’ll try to seal some of the old one’s front sided cracks.
Rear brake calipers replaced. All pads replaced.
A/C vacuum hose that was fu<ked up by HummerWhore was replaced. Blower and motor replaced. A/C blows cold. Heat blows hot.
Ball joints replaced.
Hubs checked. Fluids replaced.
CTIS leaks identified as at hub inlets so now I know what to rebuild after I source parts.
Darned CTIS alarm unplugged until I actually engage the CTIS system.
Now time to drive and enjoy.
TOBASH
3,945
Brooklyn, NY
Shaking her out, driving to work.
New brakes catch/pulsate. Gonna see if a little wear smoothes them out.
A/C drips. Gonna wait on fixing that until Autumn.
Gonna rip off the rusting brush guard and weld up a new better one soon.
Rusting roof rack has gotta go. I’ll keep the feet and weld up a superior unit this Autumn.
Really fun to drive to and from work while shaking her out.
TOBASH
3,945
Brooklyn, NY
As a favor to Tor, I drove to deliver a replaced part from Tor to my friend George. Tor worked on his truck and replaced the steering gear.
George owns three Hummer H1’s.
Turned into a Hummer jamboree and photo op.
TOBASH
3,945
Brooklyn, NY
IMG_5825.jpegIMG_5830.jpegIMG_5828.jpegIMG_5829.jpegToday I swapped in new LED headlights.
My vehicle had some type of upgrade. Halogen or Xenon. I have pictures. There was an energizer on the back of the lights and an extra power plug with a strange connector. It provided crap illumination.
I swapped in Amazon $60 headlights I bought years ago and meant to use on my M1025. Instead I used them for the 1995 Hummer Slantback, and they are much more powerful. I hear they might fog up but I will wait and see. If they fog I will drill in hoses to allow the HVAC to blow them clean just like old hoodtachs from 1969 GTO’s. I’ll hook up the outer headlight “eyes” tomorrow. I got these in just before the Heavens opened up with thunder and lightning.
I took pictures of the difference in illumination between the newer headlights (passengers’ side), and the older headlights with the weird energizers that I guess are Xenon (drivers’ side).
TOBASH
3,945
Brooklyn, NY
Been busy.
Had a hot second today to make a small change, but it’s the little things that make all the difference.
Rusted lug nuts going away. New black ones from Amazon installed. Cleaned up the wheels nicely. IMG_6017.jpegIMG_6019.jpeg
Old bolts will get muriotic acid and black paint and will be recycled onto the M1025.
TOBASH
3,945
Brooklyn, NY
At roughly 2700 RPM I have a screaming pulley. I’m hoping it is not the Whipple. Stay tuned. 1995 GM 6.5 NA block.
