looking for filter numbers
davidkroberts
24
west tennessee
Ive done a search both here and on google and am wading through tons of info but none that i need.
does anyone have the civilian filter numbers for a MEP-003A generator. Ive found it for the MEP-002A which i also have but cant find it for the 10KW
Please Help!!!!!!
Dave
doghead
4 Star General /Moderator
1,187
NY
I thought they(filters) are the same(mep003a and mep002a).
Earth
Corinth Vermont
I'm trying to cross reference the fuel strainer element part number to NAPA and they can't find anything. Tried Autozone too. What are you guys doing for this part? I have one genset that had the filters removed. Thanks
ammodude
McAlester, Ok
Got a MEP003a W/106 hours:grin: and no filters:cry:.
Cross referenced to NAPA parts.
Air filter: NAPA FIL 2222
Oil Filter: NAPA 1004 (outer gasket does not work)
Oil Filter Gasket: NAPA 5108 (OD 4.458, ID 4.250, CS 0.125)
Fuel Filter: NAPA 3113 (Gasket included NAPA 5131 works)(must open up the tabs carefully)
Fuel Filter Gasket: NAPA 5131 (OD 3.587, ID 3.317, CS 0.125)
Fuel Strainer: Haven't found a commercial one yet.
00257-0067 BAE SYSTEMS LAND & ARMAMENTS
26611 CATERPILLAR INC.
21621-6 CUMMINS INC
35070 HONEYWELL INTERNATIONAL INC.
9500-0229-2 HONEYWELL INTERNATIONAL INC.
BM49891 LA GARY CO
30554-70-508 LIBBY POWER SYSTEMS LLC
191442H1 NAVISTAR INTL CORP
149-1469 ONAN CORPORATION
4F3 OSHKOSH CORPORATION
FX3 OSHKOSH CORPORATION
752002-01 PUROLATOR FACET INC.
F6X12AT3 ZENITH FUEL SYSTEMS INC
F6X12T3 ZENITH FUEL SYSTEMS INC
Check your fuel pump strainers, mine were clogged. I need to clean out the fuel tank from the triple rinse.:cry:
I replaced my missing oil filter spring with a GM 350 engine valve spring. No spring retainer.
I am use the element oil filter until I can machine a custom spin on adapter plate.
Will be replacing the fuel filters with spin on adapters as I collect them, a couple of WIX 24770 bases probably.
Oil and fuel Filters are same for MEP002, parts manual lists a different parts number for the oil filter base but the canister and oil filter group is the same. The oil filter gasket is slightly larger with a OD 4.5, CS 0.125.
BradBMI
NYC/NY
I have a MEP-007b, MEP-805a and MEP-806a I am going to overhaul.
Anyone know the napa (or other) part numbers for the filters on these units
I searched a few but am having a headache tracking them down, The units came with the filters missing. I have the cans but need the elements
Thanks Brad
stkcode
Apple Valley, CA
Kind of an old thread, but here is what I have for my MEP-805a. Along with some other cross-references. The filters should be the same for the MEP-806a as well. It appears the John Deere 4039T and 6059T both use the same filters.
Oil Filter Element
- Fram PH20/PH20A
- Napa Gold 1243
- Baldwin BT259
- Fleetguard LF678
- Donaldson P550020
- Wix 51243, 51243MP, CW243MP
- John Deere AR58956
- New Holland LF0067800
Water/Fuel Separator Filter Element
- Fram PS7407/PS7407A
- John Deere RE50455, RE58367, RE62418, RE64449
- Fleetguard FS19516
- Baldwin BF1203
- Donaldson P550351
- Wix 33531
Crankcase Breather Filter Element
- WIX 42841
- Napa 2841
Intake Air Cleaner Filter Element
- Donaldson P182059
- Fleetguard AF1733KM
- New Holland AF0173300KM
Hope this helps ya out. :mrgreen:
Ray70
6,772
West greenwich/RI
The PN's that Nonotagain listed are all correct, but I read somewhere that some have wrong size gaskets ( as you found ) and I think the Napa/WIX oil filters need the tabs in the center of the filter bent in to clear the center tube. I know many folks dislike Fram, but they were the OEM filter and they fit perfectly out of the box. Rockauto.com has the oil and fuel for cheap, but not the fuel strainer. So far all mine had strainers that I was able to clean. Ok, I'm ready to be bashed for using Fram filters now... :lol:
