Pa Well Driller
- 13
- 3
- Sligo Pennsylvania
I have a 1970 M35A2 that is making oil. I did the FDC bypass then pulled the cover with the shut off cable and can see fuel dripping from the shaft while the electric fuel pump is running. I would like to find the gasket for that cover and o ring for that shaft and also the o rings associated with the hydraulic head, and any parts/seals needed for the mechanical fuel pump , should I need to go deeper. Thanks in advance for any direction on obtaining these parts.
