Looking for PTO control lever
OD_Coyote
58
North Bend, WA
Thanks for the info Armada...I have a line on an original used PTO lever and Saturn has the lockout plate, so if memphis or seco have the mounting bracket I should be set.
FreightTrain
Banned
2,730
13
Gadsden,Al
Post what you find and prices.I also need all this.Currently I only have a winch installed plus a drive shaft(needs new U joints) and Front PTO sitting in my shed awaiting install.
OD_Coyote
58
North Bend, WA
FreightTrain - I am in a similar situation. I am still waiting for the winch to ship and I still need the drive shaft and PTO lever mounting bracket.
This is what I have so far...
PTO - $150 (Ebay)
Winch - $500 (SS Member)
Used Lever - $25 (Ebay)
PTO Lockout Plate- $6.50 (Saturn)
Armada
Buick City, MI
Sam Winer has pto drive shafts for around $100, and the lever bracket from Memphis was around $65. Don't forget you will need an attachment sleeve on the pto and the winch for the drive shaft. This part is exspensive if bought new. Sam Winer has them for $80 IIRC, maybe a little less, and they are a spicer part. The u-joints come with the drive shaft. Not sure who has the pto lever data plate that mounts on the trans tunnel in the cab. And if you get the Memphis pto lever, the notch in the lock out plate will have to be bigger.
