Low Power
Kernel Klink
Newnan Georgia
New to site. Just bought another M35A2 having some trouble.
Fuel smells like paint thinner and low power 35 mph top speed.
Had leaking head gasket changed head gasket still low power.
Need all the help I can get.:cookoo:
2,499
Did you buy the truck from Wreckerman??rofl
OK...sorry...change the filters? Clean the tank/fresh fuel?
That's a good start IMO.
Akicita
Eastern Pennsylvania
You get more power from diesel. If you have some mix in the tank that includes paint thinner, you're not gonna get the performance you expect and may even be heading towards trouble.
If the tank is pretty empty, you may get away with filling it up with diesel. If is still pretty much on the full side, empty it out and put diesel in there.
Multifuel engines run on a lot of different fuels but not all fuels give the same grade of performance.
Also, while you're at it, check your in-tank fuel filter for algae or anything else that doesn't belong there and may clog the filter so that your engine doesn't get the fuel it needs to run better and faster. I would also replace at least the primary fuel filter.
Good luck !
wreckerman893
Possum Connoisseur
15,647
2,141
Or did you get it from this guy. (hint...he has been known to wear a pink tutu).
I did successfully run laquer thinner in one of my deuces (mixed with WMO)......never had issues except for the smell and the cleaning qualities. Had to change filters two times before all the crud was cleaned out of the tank.
3,179
Start with the easy things first. Make sure it's getting full throttle.
3,179
Ahh! I didn't think of that ^.
What kind of RPM are you seeing at 35 MPH?
Kernel Klink
Newnan Georgia
Bought from GLA. Not in low. Drianed tank and put fresh diesel, does have full throttle.
I'm gonna change filters and check the screen in the tank. Thanks for the info. WIll see if that will fix my problem.[thumbzup]
John S-B
1,264
Ostrander, Ohio
What's your exhaust look like? Is there a lot of smoke, and what color is it? I'd also check to see if your brakes are binding. You might want to check your injectors as well.
John S-B
1,264
Ostrander, Ohio
exhaust is ok s not much smoke how do i check injectors?
If you don't know much about injectors, you're better off taking them to a good diesel shop that can do it for you. But I would try all the other suggestions first, especially since you don't have alot of smoke (suggesting a problem with the combustion of fuel)
Jimma
Hartwell, GA
One of mine was doing that and changing the filters, running staight diesel with a good dose of power service additive in the silver plastic jug took care of things. Also check the air filter to make sure its not a mess or looks like it had something living in there.
gimpyrobb
dumpsterlandingfromorbit!
27,791
787
Cincy Ohio
Its easy to check the turbo if it is suspect. Pull off the tube from the air filter and see if you can move it with your fingers.
