Lu4 Winch transmission oil
Schocki123
Hello,
I own a Lu 4 Wind.
How much oil do I have to fill in the worm gear and the clutch transmission?
What kind of oil should I use?
Can I use SAE 80 gear oil?
Best regards
Schocki
M543A2
My manual TM9-8030 for the truck says one quart each end, GO (gear oil) 90. That is what we use in all of our winches with about 10 to 20% STP mixed in.
Regards Martin
M543A2
Further information; the manual specifies 90 for 32 degrees F and above, 75 weight for +40 F to -10 F so your 80 would fall roughly into the last temp range. We have never messed with changing oil for the different temps, just using 90 with STP. In cold weather we run the winch PTO with the drum disengaged for a couple of minutes to distribute the 90 then go ahead and use the winch. We have never had a problem.
Regards Martin
T. Highway
Lubricants have come a long way since the TM was published. Use ISO 460 Worm Gear lube in your winch and steering box, its made for extreme pressure. Outstanding performance hot or cold.
Bert
