m-621 project nears completion (norway deuce)
m-35tom
226
eldersburg maryland
hi all,
i have been working on this project for the last few months and await only the bed. most everything else is finished. need to mount the seats and finish the dash.
build with mostly new or rebuilt parts, new fenders, doors, hood, top. everything blasted to bare steel and 2 coats of epoxy primer, then 2 coats of eurothane .
upgrades include:
hydraulic power steering, 800 series wheel
14.5R20 michelin on 12" wheels
3 air locker axles
auto air dryer and drain
dual full air over hyd brakes
air assist hyd clutch
hemtt seats
Stretch44875
Super Jr. Moderator
31
Tiro, Ohio
Looks NICE. Sticking with the stock powertrain? I like the rims and norway axles.
Dennis
m-35tom
226
eldersburg maryland
thanks, i always thought of a tachograph since it has a clock and better lighting for the speedo and tach. i used a 5 ton cab since the steering column is further to the left, but it is also lower. need to make some refinements to the angle of the column. the air assist clutch is so easy you can push it to the floor with one finger. likewise the brakes are very easy to apply and with the michelins it stops real fast. new monroe shocks on front and 30 psi in tires, it rides better than my subaru outback.
m-35tom
226
eldersburg maryland
i made my wheels the same way joe trapp did, but i used m-135 wheels since they have a 1" different offset. this gives it the same track as a m-35a3 and clears steering. if i did it again i would do 11" wide since flaps would fit better.
houdel
10
Chase, MI
AWESOME! Great looking truck! Where did you get the ganged panel for the front axle airshift and locker controls? Is that a stock part or homebuilt?
m-35tom
226
eldersburg maryland
ganged panel is nos from a m-621, i think white owl in nc has them as well as axles. a indicator light comes on after the slider in the axle has moved to lock position.
