m1008 auxliry fuel tank
panzerwillie
295
miami florida
I help my brother hook up a M35 fuel tank on his CUCV about a month ago he uses to pump fuel to the main tank , it work out easy using the deuce and half fuel tank and pump and i just hook it up t the over flow line and its being working good, he just watches the gauge and when low just turn on the switch and watch it fill the main tank hes happy here are some pictures
OL AG '89
Kingwood, Texas
Great install, BUT.....
Some states don't allow this type of "open" system....
I hooked an aux tank to my GMC 3500, but it is isolated from the main tank by an electric valve. The installer explained that Texas does not allow an aux tank, without isolation from the main tank. The issue apparently is an uncontrolled fuel spill in a crash.
If he forgets to turn off valve, the same situation exists....
panzerwillie
295
miami florida
thats why we live in florida but also it needs to be pump out even if you pull the hose off it does not free flow, and there is electric valve sitting on the table for install that will work with the pump switch COL:driver:
