M1008 axles into a m1009
2deuce
188
portland, oregon
I'm not looking to tow or haul, but with the idea of a lift and 37" tires. It would probably need crossover steering added. I want to make this a better off road vehicle, but do you have to give up freeway traveling? If I go smaller than 36 or 37 to keep low range low enough, then what? overdrive? or are there different th400 ratios and TC ratios to look for. Anyone done this? I have an 85 Suburban for parts. I don't know if the trans or TC ratios are different than the M1009 or M1008. Maybe I didn't search good enough but I didn't see anything on this.
Thanks,
Greg
hobie237
Newark, DE
The other alternative is to get axles from a civilian truck with better gearing for the highway, like 3.73s. They won't be any different from the D60/14BFF in the 1008s.
2deuce
188
portland, oregon
Thanks for the replys. I have a set of axles from a 85 3/4 ton suburban that has 3.73 gears. The glove box says posi for the rear, its a 14 bolt. Is this the gov-lock that is so unpopular? There is no mension of the front axle so I'm guessing its a 10 bolt, but it is an 8 lug. I have access to a set of axles from a M1008 also. The wrecked Suburban I bought also had a banks turbo on it so I thought I'd swap that over also, now I'm wondering which axles to use. I'm also guessing that the Suburban TC is the same as I already have in the M1009. Is this right? Can you guys give me your opinons on which way to go.
Thanks,
Greg
AJMBLAZER
Paducah, KY
The Suburban front would be a 10 bolt. Nothing different than a half ton 10 bolt other than the parts necessary for the extra 2 lugs per side.
Yep, the factory locker would be the Gov-Lok. It's supposed to be decent in a 14FF simply because it's much larger and the carrier is huge and beefy as opposed to a 10 bolt. I'd rather have a real locker as you're still left with it's odd habits and goofy manors.
If the Suburban has OD then it has a 700R4 transmission. However I'm betting it has a TH400 which should then be the same as what you already have.
The 10 bolt front and 3.73's would be pretty good for 36's without OD. Use the diesel grunt at low speeds and at high speeds the gears would keep it from spinning the wee outta the motor. Hard wheeling might challenge that 10 bolt with tires that size though.
2deuce
188
portland, oregon
I went out and looked and its the 3 speed auto, but the glove box says auto locking hubs and it has Warn hubs on it and the spindle is different, shorter I think but I didn't measure. Also has the trailer tow package whatever that means and a 40 gal tank.
Greg
AJMBLAZER
Paducah, KY
3 speed auto = TH400
Hubs are no big deal, they failed often so manual hubs are a common swap.
Trailer tow package generally meant bigger rear drums, the deeper gears (sure it doesn't have 4.10's?), a hitch, and transmission and maybe engine oil coolers. Oh, bigger mirrors usually.
