M1008 radiator replacement
Enforced_Leo44
Parma, Italy
Hi everyone,
My truck recently developed a radiator leak, I think it's some sort of hairline crack between the inlet tank and the core. Brought it to a local radiator shop but they couldn't locate the leak as it apparently only leaks while it's cooling down, they just gave me a bottle of "LiquiMoly Radiator Stop Leak Plus" and said "If it still leaks, shake this thoroughly and pour it in the coolant while the engine is cold"... and asked me 130 euros for this.
I've always been quite against these radiator stop leak products because I'm afraid that they could clog some coolant passages within the engine, so I'll probably bite the bullet and get a new radiator...
I'm from Italy so my parts choice is pretty limited, RockAuto would be my best bet, so I looked on it and found a OSC 850 radiator, anybody has had any good/bad experience with said radiator?
EDIT: It's a 2 row radiator from what I read, I don't do any towing/pulling/heavy payload stuff with my truck so maybe 2 rows are enough
Thanks in advance,
Leo
Tinstar
2,625
East of Edmond, Oklahoma
Do not waste your money on a 2 row. Even without towing.
I would take it to another repair shop and see what they say.
If not, be prepared to spend some cash.
They still make the copper/brass radiator, but a lot of guys have had luck with other models.
Search or Looking back on old threads will show you the part numbers.
87cr250r
2,137
Rodeo, Ca
I tried the aftermarket 850 brass radiator and it was junk. I have an aluminum one with plastic tanks that is much better. Lately there are a lot more aftermarket options including welded aluminum units.
