M1009 DL7157 ground question
mikey
40
Lake Como, PA
I've installed a non isolated alternator on the driver side of my M1009, DL7157 from Autozone.
I understand it can only be used on the driver side and I understand it is not isolated. However, I'm not sure what I should do with the two ground cables that were connected to the isolated alternator I removed? One ground wire runs to the block and the other runs to the other alternator. There is a ground bolt on the back of the non isolated alternator. Do I ground them both there? Do I just zip tie them and not connect them at all?
I've read that the non isolated alternator does not need to be grounded as the bolts ground it to the engine. On the other hand I don't want to attach them to the ground bolt IF that may cause a problem with Gen 2.
If I do need to attach them to the ground bolt, I'll need to change the eyes on the ends of both cables because they are too small for the ground bolt.
Thanks
Mikey
rsh4364
15
greensprings ,ohio
I look forward to some expert advice on this post,I have never seen Gen 1 and Gen 2 grounded together and then grounded to block.My experience is limited to 4 local 1009s (2 of them mine) And only about 80k miles.
