m1009 HELP PLEASE
tklm539
Bolton Landing NY
Ok, I have looked and looked, where is the steering stop bolt on the m1009. Because is sure is not where I think it should be and with bigger tires, I need to adjust it.
Any help you Really, Really, Really be appreciated
CCATLETT1984
Saint Clair Shores, MI
thanks for posting the pics sermis, the bolt that adjusts the stop should be double nutted, loosen the nut turn the bolt tin to increase the turning angle then lock the nut down again, you may even need a shorter bolt if the stock one bottoms out, but fyi dont make it too much shorter, or you will bind things up.
tklm539
Bolton Landing NY
Said bolt has been found. AJMBLAZER checked on Colorado K5. It is on the backside of the passanger side C bracket.
It is much smaller than I would have thought. Translate.... I looked at it a least 5 times and did not know what it was!
Thanks all
Tom
