M1009-M1008 front fenders?
3dubs
Houston, TX
Can the M1008 front fenders bolt on the M1009? I understand 36" tires will fit the M1008 so will a fender swap allow the bigger tires without lifting? I have 33X12.5 on now so I can do any lifting to get ready but I would like to do as little lifting as possible. I thought about cutting the finders but would like a more stock look.
3dubs
Houston, TX
I want to run HMMWV tires. So 36 to 37 inch tires. I put 33's on for now. I would have liked to just change fenders. But if they are the same so I will first lift it four inches and then work all the bugs out. Then I can do an axle swap and change the tires.
