M1009 replacement instrument panel
vtjumpr
Starksboro,VT
Having trouble with the alts not turning on and charging the batts, I have tried the suggestions on previous threads and I believe I may need a whole complete instrument cluster and dummy lights. Do I have to replace a diesel instrument panel with a diesel? Or will a gas engine cluster work as a replacement? aua
dependable
188
Tisbury, Massachusetts
If you want your alternator circuits to work, the cluster has to be from another CUCV. You should try cleaning the contacts and replacing the bulbs on the one you have before you give up on it. If it has no rips in the plastic or signs of short circuit, it is probably fine.
vtjumpr
Starksboro,VT
Thanks Mate, I had a feeling it had to be. I tried new bulbs and I'll ck out mine more closely in the sunlight and retrace all my lines again.
Warthog
240
OKC, OK
Take a look at these threads.
http://www.steelsoldiers.com/electrical/43351-cucv-instrument-cluster-repair.html
http://www.steelsoldiers.com/cucv/46054-cucv-instrument-cluster-decoded.html
http://www.steelsoldiers.com/cucv/54292-cucv-alternator-symptoms-diagnosis-fix.html
Basic questions.
1. Do you have a voltmeter and know how to use it?
2. Is your truck stock as far as you know? Any modified wiring?
3. Have you checked and cleaned all the fuses in the fuse box? The very top heater fuse controls the GEN1 excitor circuit.
4. Have you checked out the wiring diagrams is the appendix of the TM 9-2320-289-20 or TM 9-2320-289-34 technical manuals? Or at www.CUCVElectric.com
The CUCV instrument claster is very basic. Unless the circuit board is really damaged you should be able to get it to work.
We will just take it one step at a time and check each part of the circuit to find the problem. Please bear with us as we step you thru it.
vtjumpr
Starksboro,VT
Sir Warthog, please bear with me. You've been great!
I do have a very good voltmeter and I know the basics of it!
The rig is mostly stock(a push button start added) otherwise it's original.
The fuse box on this one is rough but functional, I will go thru it again tho and clean it up.
I need to review the diagrams more closely, they make my head hurt!!
I'm not a mechanic and this is my first diesel.
LMC models with out Guages Circuit board 38-8036 its a printed circuit $79.95 Housing i can help with that if u still need parts Vt jumpr if u need anything pm me Good luck my friend :]:D
BTW warthog Good evening :]
