jaymcb
- 55
- 28
- Behind Enemy Lines, Massachusetts
My new-to-me M1009 has a driveline vibration and transfer case leak which led me to verify failed driveshaft u-joints, and it looks like the last owner drove with bad the bad u-joints for a while, which took out the seal on the transfer case.
I guess the question is, if I'm swapping the joints and the seal, my wayback machine mind tells me there might be a bushing in the transfer case as well. Should I swap out that as well while it is apart?
Also, any recommendations on parts? GM? NAPA? AutoZone? someone else?
Don't like the idea of ChiCom steel in my CUCV if I can avoid it.....
