m1009 upper rear shock mounts
Jd68ss
Nc
Installed a rough country lift, the rear shock mount studs they included are to small for the frame holes. The shocks i removed were worn out factory units, with the stock mounts. Do they make the replacement mounts with larger through frame studs? or do I just need to fab something up.
cucvrus
9,625
Jonestown Pennsylvania
Go back to rough country and ask them that question. Most stock shocks come with the correct mounts and frame studs. Maybe you need to remove the studs from the stock shocks and use them. I am sure they are not worn out. That lift kit stuff is mostly imported garbage that is put on trucks as an end of life support addition. I see very few older trucks that get lifted lasting very long after the lift is added. It all goes down hill fast from there. Good Luck. I answered your question.
