M1009: What Glow Plugs do I buy - I've bypassed the resistor.
MuddWeiser
Truckee/CA
I've done a little reading here and I see there are several solutions or routes to take when dealing with the glow plug system in the CUCV. I went with the "bypass resistor" option.
2 years ago I remember bypassing the resistor(?) on the firewall behind the air cleaner when diagnosing/fixing my glow plug system. I simply ran a battery cable directly from the front battery (+) to the glow plug relay by the wiper motor. This has worked fine for 2 years, and my controller card still works.
Since the truck has been reliable as a daily driver I thought I might give it a tune-up, maybe new injectors and a rebuilt IP. BUT before I did that I figured I would do a compression test to make sure my investment was worthwhile.
I went to pull the Glow Plugs and they are swollen. I'm gonna get them out either by using a tool or breaking and extracting - BUT... I am wondering:
1.) Why are the "no swell plugs" swollen!
2.) For the "bypass resistor" method mentioned above, WHAT brand and model # glow plugs should I be using?
84cucv1ton
New Jersey
i have a push button for my plugs. i have had good luck with AC 60s. the 070s i think they are called. been told they dont swell. well have many that have.
Michael
39
Fulton, MS
I use AC60G with or without the bypass. I did manage to burn out a set of them but they didn't swell. I think my relay was sticking on.
ralbelt
9
West Warwick, R.I.
I just took out the 070's , none swollen,and put in the AC 60G's. Resupplied the relay with 12V from the diamond shaped terminal just above it and replaced the relay with a ST85. WOW does it start fast [other than wait time]. Before crank time at best was 4-5 seconds now its barely 1 sec. I'm a happy camper:smile:
I did the Doghead relay Mod a year ago, no problems.
And remember boys and girls the first rule of owning a CUCV. If its rubber replace it if its electrical clean it.
Dielectric grease is your friend.
