M1010 is running
panzerwillie
282
miami florida
Well after 6 month is finally running, took a stock M1010 that was converter to 12 V and put a 96 6.5 turbo that i rebuild with new Heads and install a 4911 IP and new injectors had the 4L80E rebuild with new TQ conveter and install a new US shift optishift auxiliry oil cooler and tranny cooler will be installing a cab under the dash a/c and 3.73 gears next week or 2 will update as i do it, also made the down pipe to go outside the frame and was brougth back in under the body came out good had the local muffler shop do it from the down pipe back using a NAPA diesel muffler for now here are some pictures
chevyCUCV
Massachusetts
That thing is going to cruise with the 4l80 and the 3.73's,
Really a nice truck that is put together well. good job
Whats the trucks purpose? Camper?
1,824
Dang, that thing is nice. The wagons are really screaming my name lately. Someday. Hey Will, which truck is going to GA this year?
panzerwillie
282
miami florida
Will probably keep the stock look with new tires , may lift it up a inch or 2 but for now new tires , also installing a few gagets like tire press monitor ,inverter, rear a/c{110v} tv , micro wave a small fridge ect, if im able to make the GA rally probably will be on this truck
panzerwillie
282
miami florida
A/C
Got to work on the A/C today , i modified the radio bracket to hold the a/c unit just need to put the drier hook up lines wire it and vaccum charge hoping to have it blowing cold by early next week
panzerwillie
282
miami florida
Thanks for all the replys, i used the baumann products before and this new optishift works awson and easy to use can either just use the optishift box to make adjustments and to view many things including speed temps ect or you can hook up to the laptop , im using the stock trasnfer case that was hook up to the turbo 400, making brackets for gadgets and finishing the a/c when done will post some pictures on the weekend if completed//
1,824
I'm very curious to hear the details on the A/C install. Looking for ideas for my stuff.
panzerwillie
282
miami florida
Its pretty strait foward once the compressor is on the engine, is a standar under dash install , will have more pictures when done is all wire up just need to run hoses vaccum and charge
