m101a2 wiring help
ctmustang
Thomasville-N.C.
I've been wanting to make an adapter to use when I pull the 101a2 behind my civy truck. Problem is for some reason I can't find what I need in the tm's. I need a pic of the plug on the trailer showing what each pin is for. I want to make an adapter to use the 4 pin plug on my truck. I've even tried searching the deuce tm's with no luck. So if anyone can help an old fool it would be much appreciated.
Thanks,CT
PA GasPasser
The Keystone State
Thank YOU! I've been googling this for the last hour--to no avail. I (usually) find better results that way rather than use the forums (or any forum's for that matter) search function.
I'm waiting for my EUC to clear for the M105A3 I won last week at Mechanicsburg. This is my first EUC, so I understand it can take some time. I can drive (or in this case tow) equipment out the gate there. Now to get this completed, so I won't have to put it on another trailer to bring it home.
Scarecrow1
Florence , S.C.
I would always carry what I called a( tow )box in my truck with a set of magnetic tow lights just in case along with tie downs, Spare bulbs and such.........
