JohnFire
- 5
- 18
- Pottsville, PA
I too have looked at the dakota gauge setup but the $600 price tag is really keeping me from doing it. plus I would want to add the cruise control on it as well
I got the gearbox to correct mine for $68 including shipping.AJMBLAZER said:I like that it has the speedo adjustments built in. That's over $150 to fix it at the transfer case so I figure that makes it a $450 or less gauge cluster. Start pricing gauges and you'll see the Dakota setup gets affordable really quick.
Cool!!AJMBLAZER said:-It can be used with diesels and does have a WAIT TO START light option.
It can run off of ONE of the alternators, and will do exactly what you need.AJMBLAZER said:-The diesel tach would require one of two pickups, either from THE alternator or in the bellhousing off of the flywheel. Alternator sounds easiest but then we have two and a 24 volt system...can we work around that?
Maybe they could just make it so it reads the 24v range? The idiot lights arent really needed if you have a good volt meter... It will tell you right away if one quits.AJMBLAZER said:-GEN 1 GEN 2 lights not sure, sounds like their setup is meant to just read the volts in the system as it's meant for single alternator setups.
Interesting... mine does the same thing!JohnFire said:I personally am waiting for my speedometer to blow up. When it is cold out it makes a terrible noise and spins way tooo fast ie: saying I am doing 90+ when I might be doing 45-50. Once it warms up it goes back to normal.
