M105A2 brake part #'s
jasonjc
291
Gravette Ar.
As the title says does any one have the civi part #'s for the brakes on the M105 M103 trailer. They seem to use the same brakes as my lube trailer and I want to rebuild the MC,wheel cyclinders and air pots. The TM for the lube trailer lists part numbers that seem to be Wagners, but looking them up online at Oreilys and NAPA come up blank.
M/C kit FC13625
W/C kit F13635
Air pot diaphragm 201271 (bendix)
Does any one know if these are good #'s . I may try and go to a parts store next week,but I hate it when I get the deer in the headlight look from the guys behind the counter.:twisted:
Does any one have a Wagner brake book on PDF??
jasonjc
291
Gravette Ar.
Well as I thought O'reilys and napa both had the deer in the headlights look. For the MC and WC. Truck pro can get the 201271 I did not talk to them will check with them on the others.
doghead
4 Star General /Moderator
1,192
NY
Kipman has these kits.
jasonjc
291
Gravette Ar.
I should be picking up the new dust boots for the wheel cyclinders today will let you know the # and pic's later to day.
rosco
32
Delta Junction, Alaska
The MC is a wagner lockheed, 1&1/16" bore w/NAPA # shown above. Usually you can locate the proper part # for a MC by using the casting # on the side of the MC. Its the same for the Bolster Trailer
jasonjc
291
Gravette Ar.
I got that one off e-bay. I called truck pro with the Haldex #. They had to call Haldex about it and Haldex told them that it was military only. And that the buyer had to have a military acount to order it. I also call the truck parts place that has the ad's on here, they called me back and said it would take 60-90 day and was a lot of $$. Like over $100 I think they said. This one does cross to the old one so it is the right one to get/use.
jasonjc
291
Gravette Ar.
Opps I got got side tracked.:oops: It was brought to my atention that I did not get the dust boot #'s.
Well this is what NAPA got for me. We looked thought the book and the pic in the book looked to match up good but what they sent does not look the same.
The P/N is 14492
and here is what they look like, frist is the old one the rest are the 14492's they look small but seem to lock on good.
jasonjc
291
Gravette Ar.
The copper washer for the banjo bolt are:
These are NAPA numbers
The bigger one is 1243 (big # on box)
1144 (smaller # on box under the 1243)
301H9456 (on the bag inside the box)
The smaller one is 1242 (big # on box)
1147 (smaller # on box under the 1242)
301H9434 (on the bag inside the box)
Ans the steel lines are 1/4" with 7/16"x24 fittings.
