M1079 Internal Dimension
Steel Soldiers is supported by:
Homeworld8118
Coos Bay OR
Through many searches I have found all the internal dimensions but one that I have been looking for. Does anyone have the internal dimension from the wall to the door openings?
MTVR
155
Portland Oregon
The 2-1/2 ton M1079 is not related in any way to the 7-ton MTVR- you'll be more likely to find help with your question if you post it in the FMTV section...
simp5782
Feo, Fuerte y Formal
1,277
Memphis, TN
I can get the specs here shortly when I get out to my yard.
simp5782
1,277
Memphis, TN
90in wide overall inside.
140 in front to rear inside to the door sill.
42 inside to the one door edge
A 934 box would be better suited for an MTVR. At around 700 square feet of space inside
Homeworld8118
Coos Bay OR
Thank you so much, could I trouble you for one last number? The main measurement that I am looking for is the measurement on the passenger side of the truck with the door open. How wide is that wall section?
