M1088 camper conversion
ckouba
2,008
Oregon
Had an opportunity to grab a set of A1R doors with much better handles, and managed to get a grille in the process. Pretty happy with the new look:
Still have a shimmy around 58 MPH, and spent a few days trying to remedy by balancing the brake drums (starting with the front 2). Despite getting them fairly well balanced, still wasn't able to eliminate the shimmy. I have another idea or two, but not looking forward to the effort to implement,
hike
—realizing each day
934
Texas Hill Country
We added Hutchinson rubber beadlocks, stainless steel ball bearings and fish weights opposite the CTIS valves to all our tires and wheels as suggested by @Gunny 0369, Made a huge difference in our ride: https://www.steelsoldiers.com/threads/whos-running-dynamic-tire-balancing-beads.186801/post-2575708 <fixed link>
ckouba
2,008
Oregon
We added Hutchinson rubber beadlocks, stainless steel ball bearings and fish weights opposite the CTIS valves to all our tires and wheels as suggested by @Gunny 0369, Made a huge difference in our ride: https://www.steelsoldiers.com/threads/whos-running-dynamic-tire-balancing-beads.186801/post-2575708—
Interesting. Are they these:
NSN #:
2530-01-211-8405
Part #:
12301119 D4539-3
Gunny 0369
Marine Gunnery Sergeant
294
663
North Carolina
NSN #:
2530-01-211-8405
Part #:
12301119 D4539-3
that is them,
they’re quieter with those ball bearings, and they do not wear on the rubber locks as they would to steel bead lock.
There’s a great trick to installing them in the tires, collapse them down, tie them together, put them in sideways, then release the string holding them collapsed.
A scissor jack on the inside of the tire widening the beads further apart also helps tremendously on installing these.
hike
—realizing each day
934
Texas Hill Country
NSN #:
2530-01-211-8405
Part #:
12301119 D4539-3
Yes. Dave was very helpful at helping get 5 used pull outs to match closely.
Make sure you get the right size, we saw some with other vendors that were not the right width—
