M109 Electrical
Sentinel
Alabama
Need some insight as to how the 110VAC wiring is run behind the walls. I'm planning on running a 110VAC circuit out of the breaker box, down the wall (surface mounted in plastic conduit), through the wall about 4 foot above the floor, turned with an electrical LB and out the front wall on the passenger side and down about 12 inches to a waterproof 110VAC outlet box with cover.
My question is this; is there any wiring near the front corner, on the passenger side of the van, that might get in the way of penetrating the wall (inside and out) to put an external outlet on the van just behind the passenger side of cab?
Thanks,
Richard
