M109 electrical
rwbrown72
33
Mt. Vernon, IL
Can anyone give me a an overview of the electrical system inside the m109 box? Is there a TM for it specifically? I am wondering how it is powered on the inside and where the power comes from. Is there an inverter or no power while underway? Somebody please give me an overview and directions to a manual or TM or something! Thanks!
Russellaua
81
Rancho Cucamonga, Ca.
Hello Russel,
It is somewhat easy, there is a master disconnect box and a breaker box. You have the wall sockets for plugs and you have the overhead lights. The supply is on the front of the van box and is connected to the back of the breaker box. It was originally a military socket that was plugged in a supply. Many people change it because the matching plug is costly.
The big box to the left of the disconnect and breaker box is a convertor. It converts 115 volts to 24 volts! I removed it from my truck!
NO power underway with the exception of 24 volts supplied to the 2 small overhead lights.
In the disconnect box, there is a built in switch that leaves the 24 volts overhead lights on when the box is on in the off position, when the box is in the on position, only the 115 volt system works and the 24 volt overhead lights do not.
When you are using the overhead 24 volt lights there is a black out switch on the big rear door, it works in conjunction with the b.o. mode switch at the inside rear top right of the van box. Basically you can set it on b.o. mode and the overhead 24 volt lights will turn off when you open the rear doors.
I hope i answered your questions.
http://www.steelsoldiers.com/deuce-...9a3-conversion-progress-setting-standard.html
davey8943
Columbus IN
Russell,
Give WP 20 in TM 9-2320-361-10 a good read.
I will say the instructions didn't make much sense to me until I could put my hands on the switches and see the light / outlets / heater run. A thorough read will give you a good head start!
Good luck with the truck!
Dave
