M109 van wiring question
citizensoldier
19
Northern Michigan. Smelt City
Well everything seem to work good on the truck except on thing and I cant figure it out. When I push the brake pedal the front left turn signal comes on like a brake light?? How is this possible and where do start checking to solve this? I can have the parking lights on ,all the brakes lights work just fine, blinkers work fine but when I push the brake pedal the front left light gets brighter?? :roll:
This is my first deuce and I have only had it for 2 weeks so I am not sure where to start to find this... Thanks ahead of time..
1,824
Start with each light, all 4, and remove both bolts one at a time, and clean the surface. Sounds like you might be getting feedback from a bad ground. These lights ground through the bolts, both of them.
JDToumanian
14
Phelan, CA
Don't feel bad, when I hit the brakes BOTH my front amber parking lights come on!
I thought this was normal, that the truck was wired this way. But I guess I need to check grounds too, huh?
Jon
