M116A2 Rusted Master Cylinder - Total loss?
b2948kevin
Bellevue, WA
I bought an M116A2 trailer from GL in January and have just gotten around to messing with it. I opened the fluid reservoir to check the level and it was bone dry (no water, no brake fluid) with a bunch of rust inside. Even the passages are rusted closed. I'm thinking the MC will need to be replaced for certain. The piston still moves back and forth fairly easily. I disconnected the connector on the front and the line looks clear, but I can only see a little ways inside.
Here's my question - What are the chances that the rest of the system are not completely rusted and destroyed? Anyone know what the lines are made of? Anything that rusts? How about the calipers? What are the chances that these might still work?
I'd hate to buy a master cylinder and install it just to find out that the remainder of the system is a total loss.
rosco
32
Delta Junction, Alaska
Disconnect the outlet line and look. It won't be the first that needs to be rebuilt! Is the rest of the system/ line intact? You have to look underneath, to see that.
AceHigh
31
Lake City FL
The master cylinder is easy to replace. I would almost bet the wheel cylinders are bad. The master cylinder shouldn't take over a half hour.
I think this is the master:
10614, Products
Anyway, it is the same as the M101 series trailers.
b2948kevin
Bellevue, WA
Thanks guys. I was under the trailer yesterday and all of the lines are intact, I just don't know if the lines are rusted inside. No idea about the wheel calipers either.
Anyone ever had to rebuild/replace calipers on these? Is it worth doing?
RWG
Maydelle, Texas
If there is rust in the lines and system, you can get parts from a company named Dexter, whom made the axels for some of these trailers. Wheel cylinders were still available a couple of years ago. Brake lines can be purchased from Oreillys or other auto suppliers. You can fab up the system and bleed it out, using any type of brake fluid you like.
