m211
tucson john
capitan nm
:?:Hey yall, Im new here, what a cool site! I just found water in my tran.oil, no high range. Drained, filled with kerosene,got up to temp,let sit over acouple days then drained and refilled w/tranny juice and test drove and seemed to work better,got 3rd anyway in high R. Question is, has anyone ever heard of the clutch sufaces(pads) being glued on to their plates? I was told that water in the tranny w/oil would dissolve those backings and hence no pressure plate.Dont sound right, but who knows? I still need to check out 2nd in L.high and see what happens.
tm america
23
merrillville in
yes the clutch is glued on and water will make it separate .we call it pealling the clutches 'it will do it to every clutch in the trans and the bands to water also swells the seals and will make the paper gaskets turn into mush and fail
tm america
23
merrillville in
if it has been run with water in it .the trans should be pulled and completely rebuilt and all clutches and bands should be changed even if you dont see anthing wrong with them since they can peal at anytime. we see this alot when the intrenal tank in the radiator breaks it mixs water with the trans fluid making a nice milkshake looking fluid and killing the trans in the process
tm america
23
merrillville in
semi metalic clutches seem to hold up to water a little better i think they use a different glue but it.s still not worth chancing it.i use semi metalic clutches and kevlar- high energy bands and install drain plugs on any offroad trans i built that way if you submerge it you can drain the fluid refill it and ussualy get lucky
tucson john
capitan nm
m211 tranny
Thanks for the info. I think I got lucky mabbe.Trck still shifts ok so far alyhoufg I havent had a chance to fully test all gears.I never moved it when I found the pepto bismo in the tran, just flushed w/kerosene and refilled w/atf. I will let yall know how it goes later when I can fully test it,meanwhile I plan on picking some of yalls brains. I love the 211,wouldnt have anything else! Ive used mine for years. John.
