Got that out, does outer pulley come off towards you or away from you?There's a set screw on the inner pulley. It can be loosened with a stubby 7/16 wrench if I remember correctly.
The outer pulley twist CCW. There is room to put a large wrench/adjustable wrench behind rear pulley to hold it. You may have to use a brass punch on the bosses on the front pulley to get it moving. Once it's starts moving, you'll be able to spin it off by hand.Got that out, does outer pulley come off towards you or away from you?
Thanks for your helpThis is the special tool for the pulley.
Air Compressor Pulley Wrench Gas Powered M35A1
Wrench, air compressor, for M35 with gasoline OA-331 Reo-enginewww.easternsurplus.net
