m35 winch parts...
3rdaavbn
Suwanee/Georgia
Does anyone know where I can find m35a2 winch parts?
My deuce has the PTO and the shaft and no winch mounted. The winch I found has a no knuckle to attach to the universal to and no universal or knuckle.
And the drum lock pin is broken with no lever to pull pin out and lock open.
any help would be much appreciated. Thanks
OD_Coyote
58
North Bend, WA
You may want to check with George Kivett @ White Owl Surplus...He had the parts I needed for my winch and his prices are veray reasonable.
m16ty
210
Dickson,TN
If you can find a drum lock handle, you can fix the pin. Just drill and tap the end of the pin and insert a piece of all-thread. I've fixed many broken pins this way.
CARNAC
The Envelope Please.
617
Corpus Christi, TX
If you don't find a winch and the other parts by May, I might be able to help. The winch I have is way up north though.
