M35a2 brakes??
commandojd
Deshler OH
I have been restoring my m35a2 and I am getting down to the last few items to fix on my list... The main item is my brakes! I have replaced all the main brake lines, bled and put new fluid in, and removed/ cleaned the master cylinder. Everything seemed to be in working order, there appear to be ZERO leaks...but for some reason it wont hold pressure for a long period of time. About 2 months ago I re did the lines...etc and pumped the brakes up and they were functioning like they are supose to. But when I went to pick my truck up from the paint shop their was no brakes! If anyone knows what mite be going on please let me know! My buddy has three of these trucks and he never has this issue, his trucks sit for months and he can just jump in em and go with no issue. Any help will be greatly appreciated!
porkysplace
1,486
mid- michigan
Did put a rebuild kit in it ? If you used the old seals it could be leaking internally . Did you follow propper bleeding procedure ? Have you rebuilt the wheel cylinders ?
commandojd
Deshler OH
The guy I purchased the deuce from said everthing is in working condition except a broken brake line...which I repaired. The seals in the cylinder seamed to be in great shape...no visible ware. On the bleeding...I bled them properly and the brakes worked great at that time, had good pressure! The only think I didnt look at was the wheel cylinders. If those were bad, would their be some sort of leaking?
DeucesWild11
12
Putnam County, NY
There could be a leak internally in the air pack. Check the "slobber tube" that comes down the side of the engine and see if any fluid is coming out there. Sometimes when there is an internal leak in the air pack it can vent out that tube and you'll never really see a leak. I just happen to see it dripping out there. That could be where you are loosing pressure too.
The air packs are common problems on these trucks. I did a complete teardown of mine and took pics.. here's the link http://www.steelsoldiers.com/showthread.php?82753-MY-Airpack-Rebuild-with-Photos!
commandojd
Deshler OH
How much fluid do they typically take? I put one quart in...It doesnt look like I lost any...its still looks full. Ill have to go look at it again.
Heath_h49008
101
Kalamazoo/Mich
This is just an idea, but have you done a major and minor adjustment on the shoes? It wasn't listed and it would explain your issues.
If the shoe adjustment isn't done, and the wheel cylinders have to travel far enough out the the bores to get the shoes to engage and build a pedal, it would explain your symptoms.
Also, it's free, and regular maintenance that you should do anyway.
Hope it helps,
Heath
porkysplace
1,486
mid- michigan
Well since your having pressure issues with a single circut brake system and you really have no idea on previous maintainence on it. You should really should pull the drums and do a full inspection , it's the only way your going to know the condition of the brakes.
welldigger
15
Benton LA
Pull the rubber boot back on the MC and check for fluid. Also never take the previous owners word as gospel truth. But if I had to guess your problem is say either a bad wheel cylinder or your air pack is shot. As others have mentioned pull all of your brake drums off and inspect everything. Pull each rubber boot back on each cylinder and check for fluid seepage. Also check the slobber tube for any kind of fluid. Mine was full of rusty water. Apparently no one had drained the air tanks.... ever. This caused a bunch of water to get into my air pack. Which seized it up beyond repair.
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
A quick tip that has served me well through the years, instead of twenty thousandths top and ten thousandths bottom, I had adopted .015 top and bottom.
gimpyrobb
27,785
748
Cincy Ohio
Just for simplicity. I have some spare shoes(imagine that) so I never cared to watch the wear pattern. I would imagine the sand and grit I pick up while off-roading would negate the .005 difference in adjustment.
